20 years agoWatchdog has expired.
<<Watchdog has expired. Targed detached.>> I've often faced this problem when I try to debug some program, however I can't identify "who" is this watchdog. So I can't disable it. Someb...
20 years agoHi,
Today I encountered the same problem under the following operation: I reset Nios system by hardware when debugging, then NiosII IDE report the same problem... Maybe when your system broken when debugging then IDE will report this issue. FYI. David
