19 years agoWarning when exception address is changed?
I'm working on a platform which will boot up RedBoot from flash (probably running in SDRAM using a ROMRAM startup model), and then RedBoot will load applications from flash and/or the network int...
19 years agoHi Grante,
> C'mon, admit it, the warning is just plain wrong. It's a bug. Personally, I don't consider this to be a bug. The first time I encountered this warning I did some investigation to understand the impact of moving the exception address. Then I concluded that in my application, I had nothing to be concerned about. AFAICT, you've arrived at the same conclusion. But ... this is irrelevant. I'm not a Quartus developer, nor am I even an Altera employee -- I'm just another Altera user trying to contribute to the forum -- maybe save you some time by sharing my notes -- that's all. If you feel so strongly about this issue you may want to consider submitting a bug report to Altera. Regards, --Scott
