19 years agoWarning when exception address is changed?
I'm working on a platform which will boot up RedBoot from flash (probably running in SDRAM using a ROMRAM startup model), and then RedBoot will load applications from flash and/or the network int...
19 years agoHi Grant,
> It only bothers me because I still don't understand what it is > I'm being warned about. The warning states that changing the > exception address will create regions of unusable memory It's a somewhat prophylactic warning that you may be creating "holes" in your memory space where _code_ is never located -- that's all. Perhaps the wording could be better ;-) > How will having the exception address at > 0x08000000 cause any link-time issues that would be avoided by > having it at 0x08000020? In neither case will the .exceptions > section overlap the .entry section. The bottom 0x20 bytes is where the default linker scripts want to put the .reset section. In some cases, this will cause a problem -- if you use your own linker scripts you can do what you want. Just look at the manual for a description of the "possible issue". It's really not that big of deal. Regards, --Scott
