19 years agoWarning when exception address is changed?
I'm working on a platform which will boot up RedBoot from flash (probably running in SDRAM using a ROMRAM startup model), and then RedBoot will load applications from flash and/or the network int...
19 years agoPerhaps, I think that the setting of Exceation Addres is wrong of it of it with SOPC Builder.
It is necessary to adjust the address to 0x0*******20. niosii more cpu setting processor function memory module offset address reset addres ext_flash ext_flash 0x0 0x0 Exception Addres sdram 0x00000020 0x08000020 break location jtag makasete
