14 years ago
"WARNING: TX SGDMA TImeout" and no data sent
Hy guys,
I need your help, because trying to implement a SimpleSOcketSever-like NIOSII application. I built a basic NIOSII system including a 10/100/1000 TSE tx-sgda. rx_sgdma and so on. Everithing compiles correctly, at startup atuoneg and link testing succeed. But when I try to open a TCP-IP connection to the board anything happens and a message appear on the console:
"WARNING: TX SGDMA Timeout".
The same message comes out when I try to send udp packet from the board to the PC.
I checked many times the NIOSII sytem configuration but everything seems to be ok.
Where does the message come from?
Please, can anyone help me?
    hy guys,
    I got a step forward with this issue. "Warning: TX sgdam timeout" came from a mistake I added in the "tse_my_system.c".
    ANyway my problems didn't disappear at all.
    Now I can send over the net a packet, but just only one.
    I can get it on wireshark but te sendto() never exits and, from signal tap, I can see that cpu is countinuosly reading at sgdma-tx csr
    DOes anybody have a suggestion?
    What address is it reading and what is the return value from the sgdma? What is it doing on the avalon stream and m_read interfaces at that moment?
    Hi everyone,
    I am getting error as "Tx SGDMA Timeout"
    Where shall I doubt, what may be the problem?
    Did you read the suggestions in this thread and did you try them?
    My project was working fine,
    but when I am adding SRAM to the project, I am getting error as "Tx SGDMA Timeout"
