14 years ago"WARNING: TX SGDMA TImeout" and no data sent
Hy guys, I need your help, because trying to implement a SimpleSOcketSever-like NIOSII application. I built a basic NIOSII system including a 10/100/1000 TSE tx-sgda. rx_sgdma and so on. Everithin...
14 years ago --- Quote Start --- Interesting. I am having a similar problem - except that the transmit sgdma never finishes (always busy), and the receive FIFO is never emptied. Have you looked at the 'MAC Configuration Register Space' to see if the FIFO (transmit in your case) is filling up? (You might also find interesting things in those registers as well - a perusal of the options and their values may shed some light on the situation) --- Quote End --- Thanks rustycar, I looked at the 'MAC Configuration Register Space, but i don't see any way to check the fifo status.
