SeanAB
4 years agoWarning: Open not implemented
Quartus Prime Lite Ver 21.1.0 Build 842 10/21/21 - Windows 10 Host system
Eclipse Mars.2 rel 4.5.2
Trying to access a uart port via HAL API calls. The application is based on the hello world ...
KennyT_altera
4 years agoHi,
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
- SeanAB4 years ago
@KennyTan_Altera Thanks, but after some more digging and digging, I simply recreated the project from scratch and the problem is no longer there. In the new project, I choose a Blank Application template, modified the BSP to use small C library and didn't check small drivers. No problems opening a serial port for access.
