22 years agoWanring Message
Hello: I'm using Quartus 4.1 on a Cyclone device. I have a FIFO that I built with the LPM Plug In Manager. It's 16 bits wide and 256 locations deep. The output of that FIFO goe...
22 years agoassuming that inst6 is the tristate buffer. You don't seem to have a connection to the tristate. Make sure you're fifo isn't being synthesized out.
Also if you're just buffering a 16 bit bus then use the primative tri-state and just feed it with the bus (I looks like it takes a single connection but it can be bused)
