22 years ago
Wanring Message
Hello:
I'm using Quartus 4.1 on a Cyclone device.
I have a FIFO that I built with the LPM Plug In Manager.
It's 16 bits wide and 256 locations deep.
The output of that FIFO goes to a 16 bit tristate bus module (LPM_BUSTRI) also build with the LPM Plug In Manager.
I'm getting the following warning:
Warning: Port tridata of type lpm_bustri2 and instance inst6 is missing source signal
The compiler didn't warn that it removed any of the other signals in the design.
Did I miss something?
What's Best way to track this down?
George
    assuming that inst6 is the tristate buffer. You don't seem to have a connection to the tristate. Make sure you're fifo isn't being synthesized out.
    Also if you're just buffering a 16 bit bus then use the primative tri-state and just feed it with the bus (I looks like it takes a single connection but it can be bused)
    I used the RTL viewer and found everything properly connected; for what ever that's eorth.
    I also liike at the resources used and found the FIFO had consumed the proper amoune to internal RAM.
    So I suspect that everything was OK.
    I then did replaced the lpm tristate with the primitive and hte warning message went away!!!! WHY????
    The magic of Quartus hehe.
    If you can avoid Megawizard functions and use primitive then I recommend doing so (as you just found out).
    It's probably some little simple setting that you missed and it threw off the design.
