16 years agoVIP lcd demo
Hello there! I am trying to run the demonstration I downloaded from there: http://www.nioswiki.com/Nios2EmbeddedEvaluationKit/Altera's_Video_and_Image_Processing_Suite_Demo_on_the_NEEK I...
16 years agoHello!
Thanks for your reply! I downloaded the same one. Actually it was the program I was already using. It compiles out of the box in my case, but the image is swept by an horizontal line a few times, then the top blue band is replaced by a white band, then after a while the image disappears completely and is replaced by a color pattern (the image is split horizontally, the top half is a gradient from blue to lime green, and the bottom part is a gradation from red to yellow). Now I'm not sure how to set the option -O0. I right-clicked the project, went to properties -> C/C++ build and added -O0 (minus capital-O zero) in the field "compiler invocation command". Is this right? Anyway it does not change anything, I still cannot enter the functions I want to jump into (at least after the mixer is started). By the way, I am using quartus 9.1 sp2 and NIOS 9.1 IDE. Both were downloaded at the same time, so I guess they fit. Now I have rebuilt the same program from scratch (as you tell me it works fine), but I get the same result as before: no interactivity at all. Could you describe how your program works? As for mine, the image (roughly 640 x 480) is centered and it displays live video. The top margin (from the top of the screen to the top of the picture) has been replaced by a blue rectangle. That's it. No interaction although the touch panel is enabled. It never enters the while loop. As there are issues with the debugger, I print a marker everytime the loop is entered, but nothing is printed on the console, so the loop is not reached. Any idea? Thanks, Pascal
