20 years agoViewing SDRAM on Development Kit from NIOS II IDE
Hi, Has anyone used the Nios II IDE Memory view feature to view and/or modify contents of the external SDRAM on the Development kits when running in Debug mode? If so, what is the minimum...
20 years agoHow about a PLL for the SDRAM?
So, I presume that, you have a program running that change/modify/update the SDRAM, then the program stopped, and you download the dummy program (or Hello World as quoted) to monitor the memory in the NIOS II IDE? Or is it a multiprocessor, so you have the intended program running on CPU_1, and have the dummy program (Hello World) running on CPU_2?
