16 years agoVHDL Generic map
Generic map( duty => 5) I got above code from one of the LPM and need to modify it in order to make the value of duty read from another module. if I make it, Generic map( duty => n) and varie the value of n in another module (n is a signal type) - it doesn't allow. Is there any method of doing this? Thanks5 Replies
--- Quote Start --- it doesn't allow --- Quote End --- You're talking in riddles. Passing generic parameters down the hierarchy is everydays VHDL. - Altera_Forum
You must pass constants (or at least locally static values) through generic maps.
well..that's not a helpful answer to a VHDL beginner :(
"Duty" is defined as type NATURAL in the package. how can I pass the value from the top level entity? What type the "n" should be is my question. (n should vary its value at the top level entity - in a loop) - Altera_Forum
You may instantiate multiple different components with different values for "duty" in your top-level entity, but the value you pass to any one component must NOT vary. Inside what kind of loop are you instantiating this component?
If this is not helpful, please state your problem more clearly and in further detail. - Altera_Forum
Thanks immutableman :)
