17 years agoVGA Component für NEEK
Hi, i just wanted to know whether a vga component for the NEEK exists? Regards, D.
16 years agoI need some help with error issues after trying to generate the system (SOPC Builder).
As stated above I integrated the vga controller into the standard cIII system and hit 'Generate' but an error states the following report: error: one or more components could not be located (ddr_high_perf). check ip search path under tools->options... in sopc builder. error: system generation failed. I set the search path for the ddr_high_perf component to the proper IP folder where the component is located but the error will still appear. Have you some advice on this problem? Appreciate, D
