17 years agoVGA Component für NEEK
Hi, i just wanted to know whether a vga component for the NEEK exists? Regards, D.
16 years agoYes, it is in the 3165 post. You can copy the VGA_controller_component dir to your neek project's ip directory.
neek_ocm_spi/ip/VGA... Then you can add it within sopc builder. Be sure to name it as "vga_controller_0". Connect master port to ddr sdram, and slave port to peripheral bus. You will need to modify the top level design to connect the video outputs. - Hippo
