17 years agoVGA Component für NEEK
Hi, i just wanted to know whether a vga component for the NEEK exists? Regards, D.
16 years agoThank you for your fast reply!
I'm working with Quartus 9.0sp2. Target Board is NEEK. Actually "Clocked Video Output/Input" (SOPCBuilder: Video and Image Processing -> IO -> Clocked Video Output) are included in Quartus 9.0sp2. Did you mean this cores? I wanted to extend the cIII standard system files (you posted under: http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip) with a vga component and use it on NEEK. 1) Is it possible with 'modified' de2vga files and/or video output cores of quartus 9.1? The controller you mentioned is that one http://forum.niosforum.com/forum/index.php?showtopic=3165 if I'm right. 2) Could you roughly point out the changes I have to consider if the extension with de2vga is possible on the mentioned system files? Regards, D
