15 years agoVery confused rank newbie looking for advice
Hello All: I have been evaluating various ucontrollers such as the Atmel AVR line, the huge ARM family and PIC. In recent years, all my dev work has been high level PC based. The advances in em...
15 years agoThanks for taking the time Moose. You've cleared up things for me, I think. ;-)
If I understand right, it's all about fit, functionality and optimization. The NIOS is just one core implementation on the FPGA. I assume, one could implement just about any core, if the FPGA is big enough. Option 1 - Choose an off-the-shelf micro that has the features closest to the application. Write the code and you're done. Option 2 - Choose an OTS micro that has more than is needed, for future expansion. Option 3 - Choose an OTS micro and add specialized peripherals e.g. LTC 2400 24 bit A/D Option 4 - Pick an FPGA, and a core design, design needed peripherals with remaining gates then write code. Extra peripherals/ram/flash may be needed. An FPGA has the advantage of being almost 100% reconfigurable but there's an extra step to configure (and debug!) the on-chip peripherals. There may be some speed gains in implementing some functions in hardware, which would be software in an OTS device. From where I sit, the FPGA solution is not really an option for prototypes or low volume runs. Any device cost savings would be lost in development costs. If I buy an OTS micro dev board, I can buy a micro that is over the top, but then I'm coding right away. Once my design is set, I can downscale to a more appropriate device. I'm not saying this as gospel; it's just how I see things right now. If I'm missing something, I encourage you, or anyone else, to set me on the right path. Cheers, Bob
