19 years agoVersion Control of Quartus Project...
I have looked over altera's suggestions for archiving projects (http://www.altera.com/literature/hb/qts/qts_qii54017.pdf), but they appear to have left out some important cases, namely, component...
19 years agoThanks for the advice Izi. It works like a charm now!
--- Quote Start --- originally posted by iztok.jeras@Nov 8 2006, 04:21 AM - you may create a separate project for sopc components, where there are only component directories with those .pl and .ptf files. than add this project dir to the sopc builder list of directories containing components. this way all your sopc components will be stored at a single place, but you may have problems archiving projects.
inside sopc -> file -> sopc builder setup ... -> component/kit library search path
put the absolute path to the dir with your components into the box.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19286)
--- quote end ---
--- Quote End ---
