15 years agoVerilog Program - Need help with it
Hello all, I have no clue about Verilog and I want to understand a bit of program that might be useful to me. Would you happen to know what this means? I am trying to convert that into VHDL. I gue...
15 years agoWell I had a longer answer here but the forum didn't save it.....
With an HDL file open in Quartus try "Edit" --> "Insert Template" and you'll find to code fragments you can use. Here is a good document as well: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
