20 years agoVerilog DMA Controller
Hey there, I'm trying to create a state machine that will properly control a DMA which reads from SDRAM and writes into on-chip memory. The transfer width is 32-bit word only, and the ...
20 years ago --- Quote Start --- originally posted by rhaikh@Jan 17 2006, 06:21 PM nope, i read up on the avalon bus and implemented those signals within my custom logic, and created an sopc builder component. the dma_control_master port in my component connects to the control_port_slave port on the dma.
that's a cool link, though...
anyway, after looking at the internal dma signals (i.e. staring at modelsim until lightbulbs went off), i figured out that it's actually just not getting the proper address.
i send it a 32-bit address, 0x00000003, and it reads a 3-bit address 0b000. when i send it address 0x00000006, it reads 0b001. so my guess right now is that it's somehow getting address [4:2] instead of [2:0] for some reason.. about to give that a try. doesn't really make sense, but the problem is definitely in the address...
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12256)
--- quote end ---
--- Quote End --- Yep, that was totally it. I'm not sure if I'm going to try changing my address signal to 3 bits from 32, or if I should just left shift all of my address values by two.. To be clear: I was trying to write to address 3, and it was reading address zero. I sent it address b01100 instead of b011, and sure enough, it read b011 - [4:2] instead of [2:0].
