21 years agoVerifying EPCS images
QII4.1SP1 I have both an EPCS header and a Jtag header which allows me to use sof, pof or jic. The sof and pof files are default outputs of Quartus. The jic file is produced from the defaul...
21 years agoI believe you can examine the contents of EPCS; you may have to play around a bit. The idea is to do an "examine" and then File --> Save as (although I'm probably not 100% correct on this -- I'd imagine there is some Quartus literature that explains it).
One other thing that comes to mind (but not explained by the similar sizes you report): In the quartus covnert programming files tool you can optionally turn on/off FPGA bitstream compression when creating your JIC file. I believe you have to select the FPGA-configuration and then hit the properties button to display this dialog. This would indeed change the configuration data significantly.
