17 years agoVerifying downloaded data to target failed
I had converted a function in my program to a hardware using the C2H accelerator. But when downloading the program on the target kit, verifying failed at the Nios II exception address ( 0x04120020 ):...
16 years agoFrom my own experience of the results of this test I would start checking the pinout and offchip timing. The C2H accelerator is sitting idle in your system now so I suspect that the inclusion of the accelerator simply changed your fitting results from barely working to functionally failing.
