16 years agoVerify problem while runing on Nios II hardware
Hi there, when i try to run my project on the Nios II hardware i get the following problem: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Processor is already paused Readi...
16 years agoCheck for proper pin assignment of -
1. Clock 2. Reset Also check in 'system library properties' that you are using on chip memory, and not sram, as program memory
