20 years agoVerify Failed
Hello everybody. I'm having problems with a custom board. Using Quartus 4.2 and NIOS1.1 everything works fine. I decided to move to Quartus 5.01 and NIOS II 5.01 and the same projects ...
20 years agoHmm I have similar problem here.
I was able to compile and run the 'custom instruction tutorial' with version 5.0 QuartusII and NiosII. Now I removed them and install version 5.1 of QuartusII and NiosII. With the same project, I am keep getting below message. I am using UP3 Board with Cyclone device. I didn't use SDRAM, I am using SRAM only. Does anybody have idea? Using cable "ByteBlasterII [LPT1]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00020848: verified Downloading 00000000 ( 0%) Downloaded 54KB in 1.1s (49.0KB/s) Verifying 00000000 ( 0%) Verify failed between address 0x0 and 0xD663 Leaving target processor paused
