20 years agoVerify Failed
Hello everybody. I'm having problems with a custom board. Using Quartus 4.2 and NIOS1.1 everything works fine. I decided to move to Quartus 5.01 and NIOS II 5.01 and the same projects ...
20 years ago --- Quote Start --- originally posted by rj043@Nov 30 2005, 06:35 AM hi all,
i had the same verification problems while working with an up3-development board. there the problem was caused by an incorrect sdram-timing.
but there also a lot of other threads, dealing with this problem. may be it's interesting to know, that the verification function can be turned off. just search this forum for "no-verify". there a guy explained how to turn off this feature.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11265)
--- quote end ---
--- Quote End --- I have encountered this problem many times, most of the cases are caused by the RAM of NiosII, I mean the sram, sdram etc. First of all, be sure that your ram working properly
