20 years agoVerify Failed
Hello everybody. I'm having problems with a custom board. Using Quartus 4.2 and NIOS1.1 everything works fine. I decided to move to Quartus 5.01 and NIOS II 5.01 and the same projects ...
20 years ago --- Quote Start --- originally posted by luisalba@Nov 11 2005, 01:42 PM hello everybody.
i'm having problems with a custom board. using quartus 4.2 and nios1.1 everything works fine. i decided to move to quartus 5.01 and nios ii 5.01 and the same projects that worked correctly with the old version failed with the new one:
using cable "usb-blaster [usb-1]", device 1, instance 0x00
pausing target processor: ok
reading system id at address 0x021208b8: verified
downloading 03000020 ( 0%)
downloading 03010000 (74%)
downloaded 86kb in 1.1s (78.1kb/s)
verifying 03000020 ( 0%)
verify failed
leaving target processor paused
almost always i get this error and i really don't know why. ther is sdram at 3000020, but i think the sdram is not the problem because with the old version everything worked fine.
have someone had the same problem before? please help!!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10929)
--- quote end ---
--- Quote End --- http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif Hi luisalba i'm getting started now with a stratix II (EP2S60F1020C4) and i had the same problem : Verifying 03000020 ( 0%) Verify failed Leaving target processor paused. I solved it by downloading an the board the standard.qpf file that i found i the directory: altera\kits\StratixII_DSP_Kit-v1.1.0\Examples\HW\NiosII\example_designs\vhdl\standard I have downloaded this file without compiling it. I started Nios II IDE and runned a sample project unchecking Validate Nios II System ID before software downolad. Everything works fine now.Good Luck and sorry if said incorrect things but i'm not so expert as you! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
