20 years agoVerify Failed
Hello everybody. I'm having problems with a custom board. Using Quartus 4.2 and NIOS1.1 everything works fine. I decided to move to Quartus 5.01 and NIOS II 5.01 and the same projects ...
20 years agoHello,
I posted below on another thread but it looks pertinent here as well so I thought I would put in my two cents. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Just a note:We made a custom cable and emulated ByteBlaster II with on-board circuitry.Even though Altera recommends USB Rev B I believe for debugging , this works well enough. Regards, -Baycool ******************************************************************* Hello all, I am re-releasing a custom development board that was running with 5.0(FULL) now with 5.1(Web). I get the infamous: Verify failed Leaving target processor paused Normally, I would also suspect hardware as a first option. However, I switched PCs and re-ran my 5.0(FULL) and my development board is working fine. So Hardware IS NOT ALWAYS A CULPRIT HERE. What I did to port 5.0 Full to 5.1(Web) 1. Delete old NiosII Core 5.0 (Licensed) and insert time-limited 5.1 core(Reset my processorrs characteristics : fast, no tightly coupled memory, etc.) 2. Loaded Virgin machine with 5.1(Web) , 5.1(Megacores) and NiosII5.1 eval(time-limited) 3. Had to edit qsf because I had incremental compiles set and Web5.1 does not support. So now with 5.1 (Web) -Recompile worked fine. -Program of device successful Run SW -SYSID verification okay - Get Processor paused message( Verify Failed) Any thoughts? Thanks, -Baycool
