16 years agoVerify Failed in Nios II
I keep getting some variant of the following message:
--- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x01 Processor is already paused Reading System ID at address 0x000010F0: verified Initializing CPU cache (if present) OK Downloading 00008020 ( 0%) Downloaded 4KB in 0.0s Verifying 00008020 ( 0%) Verify failed between address 0x8020 and 0x8D93 Leaving target processor paused --- Quote End --- I have searched the forums and found several good pointers, but so far nothing has worked. I've spent a lot of time now, trying to optimize my PLL for the SDRAM phase shift timing. I am using Cyclone II device, so an external (e.g. e0) PLL output is not an option. However, I am seeing the problem even when trying to Debug with the hello_world_small example, with all of the memory selections as on-chip RAM. Older designs of mine still work just fine, but if I try to change even the slightest (seemingly unrelated) thing, I run into the same problem. Any more pointers? Thanks in advance!14 Replies
This should be sufficient to hardcode the pin high:
output wire reconfig_req_n; assign reconfig_req_n = 1'b1; - Altera_Forum
--- Quote Start --- This should be sufficient to hardcode the pin high: output wire reconfig_req_n; assign reconfig_req_n = 1'b1; --- Quote End --- Thanks, BadOmen, I agree with your tip, but I was looking for some way to do this in a transparent mode for the code. Please follow my thoughts. Regardless of a developent kit that supports Nios or not, if I want to implement a simple truth table in my development board, one of the possible ways to do this is:- write my truth table HDL code and compile it;
- go o pin planner, perform a pin association with my logic inputs and outputs and compile my code again; and
- download my .sof to the board.
This hardcoding is only necessary if you have a board that has an external configuration system supporting the reconfiguration request pin. Typically the board has a pullup on the signal so if your design doesn't drive the pin then the pullup will make sure the external hardware doesn't attempt to reconfigure the device. Often designs that don't drive this signal out reserve all unusued pins as input tristate which has the same effect.
The only reason why I brought up this pin is because when this thread started Quartus used to tie unused I/O to ground by default which would cause this reconfiguration cycle to constantly occur if your user design didn't contain that pin. So if your user design doesn't have that pin and you are running into this issue it might be just a matter of going into the device and pin options and changing the unused I/O setting from ground to input tri-state. Note this isn't a Nios II or Qsys thing it has to do with the board being driven a signal and the possibility of Quartus pulling that signal low if you don't have it in your design. - Altera_Forum
--- Quote Start --- This hardcoding is only necessary if you have a board that has an external configuration system supporting the reconfiguration request pin. Typically the board has a pullup on the signal so if your design doesn't drive the pin then the pullup will make sure the external hardware doesn't attempt to reconfigure the device. Often designs that don't drive this signal out reserve all unusued pins as input tristate which has the same effect. The only reason why I brought up this pin is because when this thread started Quartus used to tie unused I/O to ground by default which would cause this reconfiguration cycle to constantly occur if your user design didn't contain that pin. So if your user design doesn't have that pin and you are running into this issue it might be just a matter of going into the device and pin options and changing the unused I/O setting from ground to input tri-state. Note this isn't a Nios II or Qsys thing it has to do with the board being driven a signal and the possibility of Quartus pulling that signal low if you don't have it in your design. --- Quote End --- Perfect. Thank you again!
