16 years agoverify failed in DMA
Hi all: Recently, I ws debugging the function of DMA module. In the Sopc Builder, the read-master linked with SDRAM and the write-master linked with on_chip_memory. In addition, one CFI_Flash ...
16 years ago --- Quote Start --- Thank you for your help! In my project, there are only on_chip_memory and cfi_flash for reset vector and exception vector, though there are SDRAM controller in the project. I do not know why. Have you ever encounted the problem? --- Quote End --- maybe you can try setting the reset vector on "on_chip_memory" and the exception vector on "cfi_flash"
