16 years agoverify failed in DMA
Hi all: Recently, I ws debugging the function of DMA module. In the Sopc Builder, the read-master linked with SDRAM and the write-master linked with on_chip_memory. In addition, one CFI_Flash ...
16 years agoThank you very much! I am very sure that the ptf file is given to the Nios II IDE. I have a question. Would it be possible to load the program with flash memory. Because I tried to make it in other project, and it appeared the same problem. If I use the SDRAM memory to load program, then it is OK. So, what is the problem?
