16 years agoverify failed in DMA
Hi all: Recently, I ws debugging the function of DMA module. In the Sopc Builder, the read-master linked with SDRAM and the write-master linked with on_chip_memory. In addition, one CFI_Flash ...
16 years agoHi gowilliam
Verify wether the correct ptf(generated by sopc) file is given to niosII ide check in sytem library properties if verify failed error came and you are not able to port into nios processor than i think its a ptf file mismatch only regards M Kalyansrinivas
