13 years agoVerify failed between address 0x4011800 and 0x401181F
I have this error on my two project without I had change nothing! Exact same error, but not same card!? (Bemicro and DE0-Nano) The only change I can find, it's the end of my subscription. I d...
13 years ago --- Quote Start --- It's the reset 0x04011800 - 0x0401181F epcs_flash_controller 32 0 --- Quote End --- This is the nios bootloader address (I thought this was excluded from verification, but probably I was wrong). Do you use a standard bootloader? Check if you changed the epcs_controller_boot_rom.hex file in the Quartus project. You can regenerate the file by rebuilding the Qsys module.
