16 years agoVerification Error when using SSRAM for NIOS II
When I've been going to load my code (.ELF file) onto the NIOS II, I'm getting an SREC verification error. I was originally using on-chip memory for the NIOS II, but I have changed it so that I am u...
16 years agoThank you for the response again.
Is there another JTAG debugger other than the one accessible from the Command Shell? I've attached a screenshot of my results from EDS command line, which are the same unfortunately. There weren't any extra debugging options available to help with this situation either.
