11 years agoVector sizes for Qsys generated HPS memory pins
I'm using SoCKit rev C, SD Card image 14.0 from Rocketboards, Quartus II 14.0. All the reference designs I've seen have the following in the Qsys generated port list of the top level soc_system...
11 years agoLooks like you setup the memory to be only 8-bits wide and have two fewer row address bits than the design at the top uses. That means the span of the memory you setup is 16 times less than the one at the top.
