11 years agoVariable Precision DSP in Arria V Devices
hey folks, I am new to altera stuff. I am porting my design from xilinx devices to altera devices. In that process am facing problems with DSPs porting. I am not finding dsp in altera similar...
11 years agoNowadays (and has been the case for at least the last 10 years since Ive been in the industry) LUT usage is really not a problem. The bottleneck is usually the RAM or DSP usage. So using luts for an adder is really not a problem.
Also, with good pipelined design, in things like the stratix 4, acheiving 300MHz + is not a problem. So the question is - what is your target device? for easy implementation - why not go with the following code? it will infer a multiplier and an adder and should give a high fmax:
signal a,b,c : unsigned(17 downto 0);
signal mult_out : unsigned(35 downto 0);
signal out : unsigned(36 downto 0);
process(clk)
begin
if rising_edge(clk) then
mult_out <= a * b;
out <= mult_out + c;
end if;
end process;
