16 years agovariable : on DRAM AND 32-bit align
Hi all,
I have my own DRAM controller named "mydram" in SOPC. In NIOS IDE project , I create a project named A following "Hello World" template. Then I put code and data of a on onchip memory by specifying in Properties of A_syslib. In helloworld.c , I declare this to have a variable putting on my DRAM controller : unsigned int arr __attribute__ ((section (".mydram.rwdata"))); Or this to have its address 32-bit aligned (on onchip memory) : unsigned int __attribute__((aligned (32))) arr; What should I do to have arr BOTH on DRAM and 32-bit address aligned ? I tried this but failed : unsigned int arr __attribute__((aligned (32))) ((section (".avalon2scb.rwdata"))); Regards, QuanNo RepliesBe the first to reply
