20 years agoV1.4 with NiosII 5.1
Has anyone tried V1.4 with NiosII 5.1? I am having problems with uploading kernel to the flash memory. -SM
20 years agosmloo,
Check out the Nios 2 flash programmers guide in the document directory of you Nios installation. It shows you how to port the flash programmer to different designs. A must once you start doing custom boards anyway. It will take a while your first time, but becomes pretty easy once you have done it 3 or 4 times. Your system clock needs to be at least 50 MHz. Doug
