20 years agoV1.4 with NiosII 5.1 problems
Hi, I am new to this stuff but here is the problem:
On fresh computer: 1) installed Quartus 5.1 Web Edition 2) installed Kit: Nios II Evaluation Edition, Version: 5.1, Build: 73b 3) installed nios2linux-1.4.zip During nios2linux-1.4.zip install strange message box appear: <div class='quotetop'>QUOTE </div> --- Quote Start --- Setup Cygwin extensions were not installed properly Please see the README for instructions on how to install them manually[/b] --- Quote End --- What does it mean? I didn't find anything about cygwin neither in readme nor in other documentation files. After that I follow Linux Quick Start Guide but at step 'Creating Kernel Project' 'New Project' dialog doesn't contain "Microtronix Nios II" folder with kernel project. Any idea where to dig and what to read to get started?1 Reply
You can try running the script : ./install_cyg_ext.sh But be aware though that while all worked with 5.0, version 5.1 created a problem with the "upload" command, so you won't be able to complete the installation of the Kernel on your board as indicated in the Quick Start Guide... Hope this helps, Best regards, Bert
