19 years agoUtility to Retrieve User Configuration?
Is it possible to retrieve the code flashed into the user configuration from one development board and download onto a second board? I am using Nios 2 stratix 1s10 development boards.
It's a long story but I no longer have the source files for the code that has been flashed and running on a development board. And now I need to run the code on a second development board. Any help would be appreciated.1 Reply
You should be able to read the entire contents of your flash into a file, convert the received SREC into a binary, use bin2flash to create a ".flash" file, and then use the programmer to program it into your other board.
The Flash Programmer User's Guide has the details for usage of the "--read" or "--read-bytes" option. You can choose whether to read only a section of the flash or the whole thing. Good luck! - slacker
