21 years agousleep() accurate ?
Hello all, Does anyone have an idea how to make sure the usleep() fonction is accurate. Whatever values I set usleep() to (which is in the range of 3 to 50), the resulting pause is in the ran...
21 years agoHello Soin,
I am using Quartus 4.2, SP1 (build 178), with NIOS II IDE version 1.1.0, build 137. BTW, I haven't been on the bench yet. I am looking at my simulation and see that accesses to certain of my regsiter file are not following the usleep() command. I am running very simple code, just accessing custom register which have their accesses interleaved with usleep() commands. I need accuracy since all my code is based on usleep() as I am driving a one-wire interface. Here is trial piece of code: IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF0000); usleep(12); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1111); usleep(3); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1112); usleep(50); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1113); usleep(80); Thanks, Eric
