DiBosco
5 years agoUsing Windows Generated NIOS Project on Linux
I've installed Quartus Lite and Eclipse as per instructions here:
https://www.terasic.com.tw/wiki/Getting_Start_Install_Eclipse_IDE_into_Nios_EDS
I have done this on Linux and Windows.
On Windo...
DiBosco
5 years agoBump. Any chance of some help on this please? Am totally stuck with this.
DiBosco
5 years agoI should also add, that even an hello world soft core project I created myself on Linux with Quartus takes AGES to do the original setup in Eclipse when you come to make a new project using the soft core. The same spinning wheel as it grinds on and on, but at least it does actually *eventually* do it, and once the project is set-up you're away.
Also, is it really not possible to edit your posts?
