20 years agousing udelay()?
Hi All, Can I direct using udelay()? Which time base be used in udelay()? Thanks in advance. Best regards,
20 years agoIn kernelspace you can use the udelay (microseconds delay) and mdelay (milliseconds delay) functions.
In userspace ("normal" uClinux C application) you can use the common usleep (microseconds delay) and sleep(seconds delay) function. I haven't personally used the sleep bu I have used usleep and udelay and they worked like a charm! So it depends on what you're writing... When in doubt i'd say go for usleep. You have to include unistd.h in order to use usleep.
