19 years agoUsing the Nios II Command Shell
Hello, Because of problems with the IDE I've decided to use another editor for coding. This has been working quite well except for everything not having to do with code writing itself (e.g...
19 years ago --- Quote Start --- originally posted by ashish@Dec 20 2006, 10:49 PM main objective of our project is to test spi master that we have built on max 2 cpld with nios acting as slave and also a host for our master.
we are not able to figure out how to use nios 2 as spi slave.
can we use spi core available with avalon interface for our purpose.
we also need ide code for nios 2 slave.
thanks in advance
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20155)
--- quote end ---
--- Quote End --- Hi ashish, I'm sorry but you're in the wrong thread for what you want. Please repost your question in the appropriate area. You will get more help that way. With that said, I'd try to help but I'm not familiar enough with Quartus to give you a good answer. I've only ever used Nios as an SPI master. Thanks, Philip
