19 years agoUsing the Nios II Command Shell
Hello, Because of problems with the IDE I've decided to use another editor for coding. This has been working quite well except for everything not having to do with code writing itself (e.g...
19 years agoHi,
If you enable verbose mode, then you'll see that all the commands used by IDE showed in the console window. BTW, could you write down your experience in a document and share with us. Thanks in advance, David
