22 years agoUsing the cpu simulator
QII4.1,SOPC4.1 web edition, Nios3.2 Trying to get the gdb cpu simulator to work. Do I need to build the code in any special way to make this work? I have tried using the same build I use for the ...
22 years agoCan I debug NiosI code on the NiosII IDE?
Does the ISS work with the NiosI instruction set? I have no Jtag, so it would also have to support using serial ports for HW debug. I suspect once my code was working on NiosII, there would be no reason to go back.
