22 years agoUsing the cpu simulator
QII4.1,SOPC4.1 web edition, Nios3.2 Trying to get the gdb cpu simulator to work. Do I need to build the code in any special way to make this work? I have tried using the same build I use for the ...
22 years agoMy suggestion, if you have access to Nios II...
debug using Nios II IDE then go back to Nios I for the final (If you HAVE to use Nios I).
