21 years agoUsing the ASMI
Has anyone here used the ASMI (Active Serial Memory Interface). I tried including asmi.c in my .c file but I get a 'no such file or directory' error. What is required to use the ASMI s...
21 years agoAh... I see. That's probably because ASMI is older than the EPCS Controller. If you have not already figured this out, the EPCS controller does everything that the ASMI device did plus it has a bootloader built into it. When looking for documentation I would look at the following links since they contain the latest and greatest information:
http://www.altera.com/literature/lit-nio2.jsp (http://www.altera.com/literature/lit-nio2.jsp) (Nios II) http://www.altera.com/literature/lit-sop.jsp (http://www.altera.com/literature/lit-sop.jsp) (SOPC Builder) http://www.altera.com/literature/lit-qts.jsp (http://www.altera.com/literature/lit-qts.jsp) (Quartus II)
