21 years agoUsing the ASMI
Has anyone here used the ASMI (Active Serial Memory Interface). I tried including asmi.c in my .c file but I get a 'no such file or directory' error. What is required to use the ASMI s...
21 years agoIt appears you are right. I just read that in the Embedded Peripherals Hadbook. The reason I was going to use it is it seems to be better documented than the EPCS Controller documentation. Also when I did searches on Alteras site the ASMI docs come up with more hits.
