21 years agoUsing the 3.3V Proto-Card Pins On Nios Board
hi, I'm using the @ltera Nios Developement Board, with the Apex20K200E FPGA onboard, for SoC design implementations. Can anyone confirm that for the 3.3V proto-card pins to be used a...
21 years agoYep, Sorry for the mistake on the first post. It should read pin_V7 is the quick switch enable pin, not pin_V6.
pin _V6 is essencial just another IO pin to the connector but with a pull up resistor on it.
