11 years agoUsing high speed USB wifi module under µClinux
Hi everybody,
I would like to transmit the highest flow of datas possible from a cyclone 2 (with clock at 50MHz) to a computer via wifi. UART interfaces are too slow, so I want to connect a wifi module to the FPGA by USB. I have learned that I have to use an operating systeme to install the wifi module driver. I would like to know if it is possible with µClinux to use module wifi with the norme 804.11g/n. All USB wifi module compatible with linux are compatible with µClinux? Thank you in advance for your answers.No RepliesBe the first to reply
