15 years agoUsing FreeRTOS with Eclipse tools.
I have been trying to get the FreeRTOS running on my cyclone iii development board using the Nios ii 3C25. I am running altera v10.1sp1 and using FreeRTOS v6.0.5 (I initially tried the very latest ve...
13 years ago --- Quote Start --- When I try to create a new project through the "NIOS II application and BSP from templates" the FreeRTOS_Demo still dissapear when I select the .sopcinfo file. This problem seems not to be solved with the SP1. --- Quote End --- Was this issue ever solved? I have the same problem. I did use Matthias' info and resources, which got me most of the way (Thank you!), but this is where I got stuck. What would be the suggested course of action? I just want to run FreeRTOS, so I suppose I could throw together a project "manually" by adding each file and resource needed, but I rather have the demo as a template. Using Quartus 12.0 and FreeRTOS v7.4.1 and v6.1.1 (same result) EDIT: I am still having the above problem, but since I got FreeRTOS working I suppose it doesn't really matter. Thanks again for the help!
